IoT
Hello guys,
i'm new to labVIEW, i need to know how to use iot platform in labview, and which is the best iot platform to upload  the data, and how to do that please if possible share with VI and description,
if anyone worked with thingspeak let me know how to write the data from labVIEW to thingspeak.
Thanks.
Message 1 of 9
(5,690 Views)
While thingspeak is mostly Matlab, there is a REST API that you could probably use (See also).
Message 2 of 9
(5,673 Views)
I'm trying to read a current sensor value in labview, that sensed value should updated to thinspeak from android app again i'm sending a data to cloud then cloud to labview. To control the relay , So how to write and read simultaneously, if possible VI please
Message 3 of 9
(5,666 Views)
You are describing sequential operations. What do you mean by "simultaneously"?
Message 4 of 9
(5,658 Views)
When vi is running continuously, data should be uploaded and at same time data should be read in labview.
Message 5 of 9
(5,652 Views)
Use two parallel while loops or do both on one loop. How fast is this supposed to run? What kind of jitter is permissible? Timing is probably not very reproducible here.
(I assume that with "running continuously" you are not using the "run continuously" button. Just checking... 🐵
Message 6 of 9
(5,646 Views)
If possible can u share the vi , and how to read and write data using HTTP Rest client.
Message 7 of 9
(5,640 Views)
Accepted by topic author MrRao
I don't have a VI because I don't use these APIs. Did you look at the links I provided earlier?
Message 8 of 9
(5,614 Views)
yes, i visited the website, thank you, for giving information
Message 9 of 9
(5,578 Views)
