Invisible terminal on BD, LV 5.1?
I have an old LV 5.1 application with an invisible terminal on the BD.
Right clicking the FP control and selecting find terminal shows the
outline, which can be moved with the cursors, but as soon as the
outline is clicked, it disappears.  Find Attribute Node and Local Variables
work, all of which are visible.  Any suggestions for how to make the
terminal visible?  Thanks.
Matt
(2,876 Views)
Are you sure it's not behind a decoration? Could you post the VI?
(2,863 Views)
Most likely, the terminal is into a diagram structure (loop, sequence, etc) and outside the structure view window. Try to enlarge the structure to view the terminal or, when the terminal is outlined, move it in sight using the arrow keys.
LabVIEW, C'est LabVIEW
(2,863 Views)
Thanks Dennis and JeanPierre.  The terminal was outside the bounds of a sequence
frame that was behind another sequence.  I could slide it outside the outermost loop,
but it still wouldn't appear.  Didn't find it until I removed each structure one at a time
in preparation for posting.  Appreciate the help.
Matt
(2,841 Views)
