Intuilink data capture cannot communicate while Labview 8.2
I no longer seem to be able to get Intuilink Data capture work while Labivew 8.2 is up.  I have to shut down one, for the other one to work.  I used to be able to have both of the programs up and be able to use both of them.  This is no longer the case.
I have attached the error message I get in Labview 8.2 when I have Intuilink up.  I also have the error message with I get in Intuilink when I have Labview 8.2 up.  I then have to shut down both programs, then start up one (say Labview), run my routine, shut labview down, then start up Intuilink up.
Any help will be appreciated to have them working together again.
(2,679 Views)
Hi hiNI,
It sounds like the board is not being addressed correctly if both programs are running simultaneously.  More information on the LabVIEW error can be found here
Has your hardware setup, software configuration, or LabVIEW code changed at all?  Do you see the error even if LabVIEW is open but your program is not running?  Also, what commands are you sending?
Jennifer R.
(2,652 Views)
