Interrupting sequence structures
Pls look at my previous post... which I have suggested...
If his project needs that and if it is unavoidable I have given a way In different way....
I mentioned it's not recommended
Thought thanks for your suggestion....
Message 11 of 14
(1,637 Views)
pls look at this post suggested earlier @nataswft
It is suggested that not to use sequence structure unnecessarily..... it's not possible to abort in case of developing applications where emergency is major criteria
Message 12 of 14
(1,626 Views)
@palanivel wrote:
@PLS look at this post suggested earlier @nataswft
Please (NOT pls!) don't clutter the forum with repetitive and trivial posts that have little to do with solving the problem.
And please use full words, this is not twitter.
Message 13 of 14
(1,616 Views)
I've seen a lot of your posts.
Here's the problem.  There's no such thing as a project where this is unavoidable.  If he needs to abort his sequential tasks in the middle, the solution isn't to further muddy the architecture.  It's to fix the architecture.
Most of your posts are trying to find a way to use tools poorly in the fear that helping them choose the correct tool won't go over well.  You're not helping anyone when you do this.  You're essentially saying "it's not recommended to use a hammer with your screw, but maybe if you use your left hand instead of your right it'll work alright?"  That doesn't make sense.  Don't advocate for bad design.  Don't find workarounds for bad design and suggest the bad design can't be avoided.  That's a terrible habit.  Instead, show people the tools that are available that solve their problem.  Not only is it possible to change the architecture here, it's REQUIRED.  Pointing me to your other posts won't change this.
Message 14 of 14
(1,595 Views)
