Internet Toolkit question
I have to do some work with this...simply view an embedded front panel
image in a html file via the internet. It will be a animated image
using .monitor
I have 2 HTTP servers. One server is on my computer using my computers
ip (start HTTP server)and the other is my isp's. My isp's HTML server
has the HTML file and embedded in the HTML file is the image source tag
with a "pointer" to my computer's HTML server...you can see one of my
examples here
http://members.home.net/cspangle/tryagain.htm
I have been playing with it at my house and the .vi image in my html
file is consistently broken. I have used both port 80 and 90 and
when I use 90 I make sure I put the :90 in the tag.
If I put localhost before the ip address then I can se
e the image from
my computer but no other computer. If I just put my ip address then I
cant see the image from any computer.
The server config is held in the .../home directory as well as the vi
and I save any changes I make to the server in this directory. Server
is running fine and front panel is up. I tried .snap as well and still
a broken image
This is driving me nuts and I wonder if it's my isp that is restricting
something?? I guess I just need to start on the network at work, but I
would like to be able to get this done here first so I know exactly
what I'm doing at work.
any ideas???
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 1 of 1
(2,776 Views)
