Cursor/Window for Zooming in Intensity Graph
Does anybody know how to create a non-rectangular window (any shape
connected by mouse clicks) for zooming (or for data retrieval) if a
particular area in the graph is of interest in a intensity graph?
Wouldn't it be really cool if we can select edges in a graph and
retrieve the information (or data) from the graph?
The other question of mine is: is there a way that when we're using
intensity graphs, we can create the custom menu with right mouse button
click, instead of the standard set of menu items? Any help is greatly
appreciated. Thanks.
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,986 Views)
In my pre-NI days, I had a lot of fun trying to coax image-manipulation and
-analysis behavior out of LabVIEW intensity graphs. You can do a fair
amount by making use of cursors and hotkeys and creating pseudo-overlays by
setting image coordinates to certain colors to create visual cues in
response to user inputs.
That being said, I never considered trying to get complex ROI (region of
interest) info from a user wi
th an intensity graph, and I'll bet it's a
pretty tough GUI trick unless you're using IMAQ Vision. If you find
yourself trying to build features like this into your application, or doing
a lot of image manipulation in general, you might save yourself time in the
long run by getting the IMAQ Vision toolkit from NI.
I'm not aware of a way to suppress the built-in context-sensitive popup
menus. Sorry!
John Lum
(2,986 Views)
