Internal Warning 0xB78CFE1B: "window.cpp"
I am receiving the following error:
Internal Warning 0xB78CFE1B: "window.cpp", line 8672
LabVIEW version 17.0.1
For assistance in resolving this problem, please contact National Instruments Support
I am running a custom UI for TestStand. The first time the application runs, it runs absolutely fine. But if I keep the top vi open (not running, but just open after the execution finishes) and I click play again, I get the error above.
I can't find the reason behind this, any ideas?
Edit:
I just realised that its saying the error is with LabVIEW 2017, I am using LabVIEW 2016 when this error occurs? (I have 2017 installed though)
Message 1 of 14
(6,182 Views)
I sometimes get the error from LabVIEW 2016 too:
Message 2 of 14
(6,167 Views)
It looks like I am getting this issue with 100% repeatability if I use the method "Terminate All" in teststand.
This is getting really frustrating, I'll contact NI help tomorrow about this, but it seems like an ActiveX reference issue
Message 3 of 14
(6,130 Views)
Hi Lbee11,
Thank you for sharing the warning info. Could I check if you have tried rebooting the computer after the error occurred? There could be a number of things causing this. The first one that I can think of is that you are loading library files made from different versions of LabVIEW. We have reproduced this problem only with Windows 10, remote desktop, and a computer with a touch screen. Are any of these relevant for your system as well?
Kind Regards,
Riley Ilieva
Message 4 of 14
(6,111 Views)
Rebooting LabVIEW solves the issue (for 1 more run anyway), rebooting the PC does not fix the issue indefinitely.
I will check any library files, but I don't think that is the issue.
I am running Windows 10, with a touch screen. I am not using remote desktop, however those features are available
Message 5 of 14
(6,108 Views)
UPDATE
I have found out some more events that occur that are related to this.
Sometimes, if the "TerminateAll" method is invoked on the TestStand engine, the report that is generated is empty. If the UI is run again, the "window.cpp" error does not occur.
If the report contains data, then the "window.cpp" error does occur
Message 6 of 14
(6,106 Views)
Here is a crash report from LabVIEW for the issues detailed above:
#Date: 27 Apr 2018 11:30:01
#OSName: Windows 10 Pro
#OSVers: 10.0
#OSBuild: 16299
#AppName: LabVIEW
#Version: 16.0f5 32-bit
#AppKind: FDS
#AppModDate: 0/24/2017 15:50 GMT
#LabVIEW Base Address: 0x00400000
InitExecSystem() call to GetCurrProcessNumProcessors() reports: 4 processors
InitExecSystem() call to GetNumProcessors()            reports: 4 processors
InitExecSystem()                                      will use: 4 processors
starting LabVIEW Execution System 2 Thread 0 , capacity: 24 at [3607669803.38711120, (11:30:03.387111187 2018:04:27)]
starting LabVIEW Execution System 2 Thread 1 , capacity: 24 at [3607669803.38711120, (11:30:03.387111187 2018:04:27)]
starting LabVIEW Execution System 2 Thread 2 , capacity: 24 at [3607669803.38711120, (11:30:03.387111187 2018:04:27)]
starting LabVIEW Execution System 2 Thread 3 , capacity: 24 at [3607669803.38711120, (11:30:03.387111187 2018:04:27)]
<DEBUG_OUTPUT>
27/04/2018 11:32:06.566
DWarn 0xFD49B614: The API version should be passed to LVDataWriter
c:\nimble\penguin\labview\components\tdcore\trunk\16.0\source\tdcore\TD80ReadWrite.cpp(152) : DWarn 0xFD49B614: The API version should be passed to LVDataWriter
minidump id: 960ef1f9-014f-42f3-ac73-336e97f6f44a
$Id: //labview/components/tdcore/trunk/16.0/source/tdcore/TD80ReadWrite.cpp#1 $
</DEBUG_OUTPUT>
0x0069C0EC - <unknown> <unknown> + 0
0x10015644 - mgcore_SH_16_0 <unknown> + 0
0x0748EFE0 - tdcore_16_0 <unknown> + 0
0x010F41CE - <unknown> <unknown> + 0
0x010FD0A0 - <unknown> <unknown> + 0
0x010FDFD6 - <unknown> <unknown> + 0
0x009700CD - <unknown> <unknown> + 0
0x00970E29 - <unknown> <unknown> + 0
0x00971118 - <unknown> <unknown> + 0
0x0097128C - <unknown> <unknown> + 0
0x007E75A9 - <unknown> <unknown> + 0
0x00EA572F - <unknown> <unknown> + 0
0x00D68284 - <unknown> <unknown> + 0
0x00EA27D0 - <unknown> <unknown> + 0
0x00D533EC - <unknown> <unknown> + 0
0x008196C1 - <unknown> <unknown> + 0
0x00E9E004 - <unknown> <unknown> + 0
0x00DDFB1A - <unknown> <unknown> + 0
0x00D532EF - <unknown> <unknown> + 0
0x00C2DDF7 - <unknown> <unknown> + 0
0x01604E74 - <unknown> <unknown> + 0
0x01608F82 - <unknown> <unknown> + 0
0x0160AACA - <unknown> <unknown> + 0
0x01EB7B07 - <unknown> <unknown> + 0
0x01F68CE5 - <unknown> <unknown> + 0
0x01EC9B50 - <unknown> <unknown> + 0
0x01EC9FB2 - <unknown> <unknown> + 0
0x757BE0BB - USER32 <unknown> + 0
0x757C8849 - USER32 <unknown> + 0
0x757CB145 - USER32 <unknown> + 0
0x757B90DC - USER32 <unknown> + 0
0x757B8C20 - USER32 <unknown> + 0
0x01F4C5CF - <unknown> <unknown> + 0
0x01F4C753 - <unknown> <unknown> + 0
0x01F4C927 - <unknown> <unknown> + 0
0x07AF1AD6 - QtManager452_2016 <unknown> + 0
<DEBUG_OUTPUT>
27/04/2018 11:32:07.786
minidump id: 7b3ae9aa-5f0c-4c2a-91eb-d24605d635e6
</DEBUG_OUTPUT>
0x00F5F961 - <unknown> <unknown> + 0
0x014FE729 - <unknown> <unknown> + 0
0x010F420B - <unknown> <unknown> + 0
<DEBUG_OUTPUT>
27/04/2018 11:32:08.168
minidump id: af2ceda4-0d53-46e5-8fa6-164ce02c83d2
</DEBUG_OUTPUT>
0x014FDF14 - <unknown> <unknown> + 0
0x014FE239 - <unknown> <unknown> + 0
0x014FE749 - <unknown> <unknown> + 0
<DEBUG_OUTPUT>
27/04/2018 11:32:08.170
</DEBUG_OUTPUT>
<DEBUG_OUTPUT>
</DEBUG_OUTPUT>
<DEBUG_OUTPUT>
27/04/2018 11:32:08.171
</DEBUG_OUTPUT>
starting LabVIEW Execution System 306708506 Thread 1 , capacity: 4 at [3607670076.44534730, (11:34:36.445347310 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 2 , capacity: 4 at [3607670076.44534730, (11:34:36.445347310 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 3 , capacity: 4 at [3607670076.44534730, (11:34:36.445347310 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 0 , capacity: 4 at [3607670113.66010860, (11:35:13.660108567 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 1 , capacity: 4 at [3607670113.66010860, (11:35:13.660108567 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 2 , capacity: 4 at [3607670113.66010860, (11:35:13.660108567 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 3 , capacity: 4 at [3607670113.66010860, (11:35:13.660108567 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 1 , capacity: 4 at [3607670126.71329210, (11:35:26.713292122 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 2 , capacity: 4 at [3607670126.71329210, (11:35:26.713292122 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 3 , capacity: 4 at [3607670126.71329210, (11:35:26.713292122 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 0 , capacity: 4 at [3607670146.02563140, (11:35:46.025631428 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 1 , capacity: 4 at [3607670146.02563140, (11:35:46.025631428 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 2 , capacity: 4 at [3607670146.02563140, (11:35:46.025631428 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 3 , capacity: 4 at [3607670146.02563140, (11:35:46.025631428 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 1 , capacity: 4 at [3607670160.36910340, (11:36:00.369103432 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 2 , capacity: 4 at [3607670160.36910340, (11:36:00.369103432 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 3 , capacity: 4 at [3607670160.36910340, (11:36:00.369103432 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 0 , capacity: 4 at [3607670171.87976930, (11:36:11.879769326 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 1 , capacity: 4 at [3607670171.87976930, (11:36:11.879769326 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 2 , capacity: 4 at [3607670171.87976930, (11:36:11.879769326 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 3 , capacity: 4 at [3607670171.87976930, (11:36:11.879769326 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 1 , capacity: 4 at [3607670191.06124880, (11:36:31.061248780 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 2 , capacity: 4 at [3607670191.06124880, (11:36:31.061248780 2018:04:27)]
starting LabVIEW Execution System 306708506 Thread 3 , capacity: 4 at [3607670191.06124880, (11:36:31.061248780 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 0 , capacity: 4 at [3607670208.75644250, (11:36:48.756442547 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 1 , capacity: 4 at [3607670208.75644250, (11:36:48.756442547 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 2 , capacity: 4 at [3607670208.75644250, (11:36:48.756442547 2018:04:27)]
stopping LabVIEW Execution System x26 Thread 3 , capacity: 4 at [3607670208.75644250, (11:36:48.756442547 2018:04:27)]
NOTE: Although the report states LabVIEW 2016 is in use (which it is), the actual error that occurs states that the labVIEW version is 2017. I don't understand how this is happening
Message 7 of 14
(6,105 Views)
Lbee11,
Have you had any luck in resolving this error? I have some members on my team experiencing the same error for a LabVIEW library built into a DLL being called from an external development environment. It seems to be related to the run-time engine in my opinion.
Ben
Message 8 of 14
(5,897 Views)
Hi
I am having the same issue in windws 7. I am using Version 16.0f5 as well.
Message 9 of 14
(5,814 Views)
Hello, any news about this error? I'm getting the same running a labview dll in a windows 10 tablet.
thank you.
Message 10 of 14
(5,569 Views)
