Internal Error 2727. NETSCAPEPLUGINSDIR
When I start Labview, labview runtime engine tries to install and gives me the above error. Even when I try to install labview runtime engine 6.1 on its own I get the same error and it says it failed to install.
(3,807 Views)
Carlo,
What version of Netscape are you using? Netscape 7 had not been released yet when LabVIEW 6.1 came out and we cannot guarantee that it will work because they might change something.
Randy Hoskin
http://www.ni.com/ask
(3,806 Views)
Randy,
We use Internet Explorer 6 now. Netscape has been removed from my machine. Will Labview 6.1 work with Explorer or do I need to reinstall a Netscape.
Carlo
(3,806 Views)
IE 6 will work just fine. The plugin for Remote Panels should have already been installed into IE when the Run-time Engine was installed. If not, the do a repair installation on the engine from Add/Remove Programs and that should fix the issue.
Randy Hoskin
(3,806 Views)
Randy
I tried the repair and a fresh install, but I get the same message during the installation and then it fails to complete the installation. Is there a way to install the Explorer plugin manually and remove the link to the Netscape plugin.
Carlo
(3,806 Views)
Carlo,
Try the following instructions found in this KnowledgeBase. It should do the trick for you.
http://digital.ni.com/public.nsf/websearch/F71BAED6AF2A6C5D86256B42006A214F?OpenDocument
Randy Hoskin
(3,806 Views)
