Interfacing Ardupilotmega with Labview with Mavlink Protocol
Sorry. i still Work on another project. What Kind of Terminal sw do u use?
and ive Some problems like u With different chipsets on rs232 converter.
Maybe try another on with another chipset
Message 61 of 75
(4,053 Views)
i solved my problem...
it was still a missing converter on hardware side.
now i use a tll-rs232 converter (SparkFun RS232 Shifter SMD) - the UART port uses other voltage levels
to view the data on the laptop, i connect the PX4FMU first to the tll-rs232 and then to the rs232-usb converter.
Message 62 of 75
(4,042 Views)
Hi,i want to read data from ardupilot by using labview,so  i use the exmple in the disscusion ,but its give me error in mavlink crc.vi    the message showing is :
""  Error 7 occurred at Call Library Function Node in mavlink CRC.vi->initialize.vi->example usage.vi  ""    thanks for help
Message 63 of 75
(4,005 Views)
achrafbak, the file "mavlink_crc.dll" needs to be in the same folder as the .llb file.  That error is saying that the library call node can not find the dll file.
CLAD, using LV2013SP1 + LV2015SP1+ LV2017 on Win7+cRIO
Message 64 of 75
(3,995 Views)
thanks       Shadowclaw           for your help,i move the following file,but it still give me error :
"Error 12 occurred at Call Library Function Node in mavlink CRC.vi->initialize.vi->example usage.vi"
Message 65 of 75
(3,976 Views)
it looks like error 12 means that architecture is wrong.  The dll is a 32bit dll which means that it will only work with 32bit labview.
Message 66 of 75
(3,971 Views)
thanks, i have windows 7 64bit,i will test it in 32 bit and report the result,
thanks again
Message 67 of 75
(3,948 Views)
whether it is 64bit or 32bit windows should not matter (I wrote the dll on a 64bit machine).  What matters is whether or not you installed the 32bit or 64bit version of labview.  I would recommand installing the 32bit version of labview even if you have 64bit Windows.  You get very few benefits out of the 64bit version of labview and in a most cases you will never notice a different between the two.
Message 68 of 75
(3,945 Views)
How do I use this software? when I open it in labview it is a whole bunch of file that seem to do different things, How do I make them all work in one interface?
Thankyou.
Message 69 of 75
(3,793 Views)
Tryingtolearn, if you are refering to my mavlink software there should be an example_usage.vi in the llb that has some comments about what pieces do what.
Message 70 of 75
(3,787 Views)
