Interfacing Ardupilotmega with Labview with Mavlink Protocol
Thanks for replying
Now I can see data like this FE  09  4E  01  01  00  00  00  00  00  02  03  51  04  03  1C  7F
Still trying to understand how this becomes flight data but I found this website which talks about it.
http://eastbay-rc.blogspot.com/2013/04/mavlink-protocol-notes-packet-decoding.html
Message 11 of 75
(5,011 Views)
Message 12 of 75
(4,996 Views)
Hey guys, I was able to get this far. I'm not sure how to binary operations like logic shifts in Labview so I used a boolean array to represent the checksum.
However, it is not displaying what the MAVlink calculated as a checksum. I might be understanding the protocol wrong.....
Message 13 of 75
(4,974 Views)
Hey I dont know if this helps but founds this vi for calulating checksum.
http://diydrones.com/forum/topics/mavlink-1-0-checksum-protocol
Message 14 of 75
(4,969 Views)
Yea, I looked at that, for some reason, it doesn't compute the correct checksum..
I'm re-writing mine today, so we'll see if I succeed.
Message 15 of 75
(4,956 Views)
It works!!!. I found my main program to be catching the wrong checksum values. I need to see what the heck is going on there.
But this simple VI works. I need to make an array table for the CRC_EXTRA byte to add at the end of payload data.
Message 16 of 75
(4,940 Views)
Heres what I got so far which seems to work at least reading heartbeat. Now I need to find out how to convert the payload data to useful values via labview
any Ideas?
Message 17 of 75
(4,924 Views)
It looks like all you have left to do is pull out those 9 data bytes from each message and convert the hex to a decimal, then apply whatever scale factor applies.
Message 18 of 75
(4,892 Views)
Thanks Karl
 It pobbley would of took me two weeks to figure that out.
Quick question and I think maxmus083 stated talking about this. How would you be able to produce the right CRC values  to check the checksum?
I know that the common.h contains which extra checksum value to use for exmaple Heartbeat (MAVLINK_MESSAGE_LENGTHS) 9 = 50  (MAVLINK_MESSAGE_CRCS) . How would I appached which value to use if some Mavlink Messages have the same lengths(blue)?
#define MAVLINK_MESSAGE_LENGTHS {9,31,12,0,14,28,3,32,0,0,0,6,0,0,0,0,0,0,0,0,20,2,25,23,30,101,22,26,16,14,28,32,28,28,22,22,21,6,6,37,4,4,2,2,.....}
#define MAVLINK_MESSAGE_CRCS
{50,124,137,0,237,217,104,119,0,0,0,89,0,0,0,0,0,0,0,0,214,159,220,168,24,23,170,144,67,115,39,246,185,104,237,244,222,212,9,254,230,28,28,132,221,......}
Message 19 of 75
(4,864 Views)
the CRC extra is added by message ID alone. so each array field number corresponds with the message ID.
so for heart beat, which is 00, corresponds with number 50 for crc extra, which in hex is 32.
there are total of 255 possible message ID's, and you will find that the array below is also 255 fields long.
so message id and crc looks like.
0, 1, 2, 3, 4, 5,... etc. with..
50,124,137,0,237,217,104,119,0,0,0,89,0,0,0,0,0,0,0,0,214,159,220,168,24,23,170,144,67,115,39,246,185,104,237,244,222,212,9,254,230,28,28,132,221,...... each one. get it?
hope that helps.
Message 20 of 75
(4,854 Views)
