Interacting with a CGI web page
Greetings NI Forums,
I am trying to develop a telescope pointing control system which needs ephemeris data generated by a Jet Propulsion Laboratory web site:
http://ssd.jpl.nasa.gov/horizons.cgi
The main interface to their horizons system is via Telnet which is insecure and no longer supported by LabVIEW.  I was hoping someone could advise me on how to get started using LabVIEW to interact with the above cgi based web page.  If I can do that, I can retrieve the required ephemeris data and parse it inside of LabVIEW using basic string commands.
Is there a basic tool kit you can point me to for interacting with web pages or any sample code?
Scott
High Altitude Observatory
Boulder, CO
(4,215 Views)
Accepted by Scott_Sewell
Use the HTTP Client VIs:
The GET VI is the standard 'give me this web page' request - give it the URL to your Ephemeris data session and the 'body' output will give you the content of the web page - if you use the plain text output then that should make parsing the string easier (no html tags etc.).
(Also, you can use Telnet in LabVIEW, there just isn't a bundled library for it any more - you should be able to use the TCP VIs to roll your own and you can also interface with other Telnet libraries/applications e.g. PuTTy...there might even be something in .NET)
(blog)
(4,176 Views)
