Intensity graph plot
Hi
I have two data file one file caries the square waveform data and other file have data which are varying with time, so I want to plot this both the data in intensity graph plot as I have sawn you in picture at front panel of  my vi. Both data should be plotted in one graph.
Please some help is required
thanks
(3,490 Views)
Hi
any body can suggest me to see square wave form in intensity graph what I have to do????
(3,449 Views)
Hi husssey,
your "xls"-files are actually "csv" files...
- Your "214" files contains only 1 row of data, seems the intensity graph expects a nice 2D array of intensity values...
- Switch on "autoscale" for Z axis in the intensity graph to see the plotted values...
To overlay your "square wave" over the intensity graph you should make the wave graph transparent and move it over the intensity graph:
The fine adjustment is up to you, usually it's easier when you use the "classic" indicators...
(3,446 Views)
hi
any body can modify it please i am new to labview user and i dont know how i can do it?
thanks
(3,440 Views)
hi
thanks
(3,437 Views)
