Intensity Graph - Mapping Mode
Hi
I have searched the NI website, and tried to search the Info-Labview
archives, with no success.
Am I able to set the Mapping Mode of the X and Y scales of an Intensity
Graph to Logarithmic (not Linear)? The Attribute Node to do this
exists, but setting it to 1 appears to have no effect, and I am unable
to select Logaritmic in the Formatting dialog box. I can set the
Mapping Mode to Logarithmic on the Z-Scale though. I am using Labview
5.1.1, Mac.
Paul Davey
Research Assistant
School of Physiotherapy, Curtin University of Technology
Selby Street, Shenton Park, Western Australia, Australia. 6008
email: P.Davey@curtin.edu.au
Tel. +61 8 9266 4657 Fax. +61 8 9266 3699
"Everyone who calls on the name of t
he Lord will be saved." Romans 10:12
"For all have sinned and fall short of the glory of God, and are
justified freely by his grace through the redemption that came by Christ
Jesus." Romans 3:23-4
(4,777 Views)
The answer is no. Apparently the developer did not see the point in supporting logrithmic scales for this type of graph. If you still want this style of graph, you can "code it yourself" with the picture control. See the picture control examples.
Stu
(4,778 Views)
Has anybody ever coded this and are they willing to share the result?
(It is the normal way of viewing a sound spectogram with a log scale)
(4,608 Views)
You could use a 3-d graph which does support log scales on all axis.
You set the colors to map to the Z-scale values and just view the graph by looking down on the XY plane.
Ben
This thread will get you started using the 3-d graph.
http://forums.ni.com/ni/board/message?board.id=170&message.id=143663&jump=true
(4,601 Views)
Thanks Ben
I will give that a try.
It would be nice if NI could kindly enable the Mapping property at the earliest opportunity.
(4,596 Views)
