Intenisty graph Z scale marker values not working
Hello ,
           I have a VI that plots Intensity graph, I have assigned certain RGB values to the Z-scale markers. But all I see is green intensity chart always.
Below I have attached the Block diagram and front panel.
Please advice where can I go wrong in this one.
Thank you
Abhi
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(2,855 Views)
It looks like you are passing all "1"s.
Probe the data to verify.
Ben
(2,854 Views)
Ben,
     Strange thing is that all is showing white now. It was working petfect untill I put in a program that shows the mouse cursor for intensity values as long as I hover the mouse above the Intensity graph.
I am attachingn a VI so that you can see it for yourself. Also a test result that shows all values are almost same. In fact its supposed to be like sine wave. To get the actual values I will have to divide by 2^14 since my AD is 14 bit AD.
But I dont really know where am I going wrong.
Abhilash S Nair
LabView Gear:
(2,832 Views)
Your zip is missing some of the VIs.  Are you using a LabVIEW Project for this code?  If not, I'd recommend it.
Also, I'm having a bit of trouble following your code.  There appear to be a lot of flat and stacked sequences nested with each other.
(2,828 Views)
