Intel 8 bit Checksum
Hi all,
Can someone please explain what I'm doing wrong to get the correct 8 bit checksum below?
I'm expecting the answer to be same as this calculator
http://www.planetimming.com/checksum8.html
Thanks in advance
Message 1 of 10
(9,936 Views)
Try this KB for calculating the two's complement. I just ran it and it got the same values as the website you posted when entering in two bytes.
dK
Message 2 of 10
(9,897 Views)
Thanks for the reply Daniel. I made few changes to meet my requirement, as per the definition of checksum. But answers are not consistent.  Please see below.
Message 3 of 10
(9,886 Views)
I think I know the problem although I don't know the solution yet.
Labview takes my input as a ASCI (ofcourse), where as I should be feeding it in HEX.
Message 4 of 10
(9,884 Views)
Accepted by topic author id911
wrote:
Labview takes my input as a ASCII (ofcourse), where as I should be feeding it in HEX.
So you have a display issue.  Right-click on the input string and you can choose "Hex Display".  If you do this, I also recommend turning on Visible Items->Display Style.  You will probably want to do the same with the indicator.
Message 5 of 10
(9,863 Views)
Problem solved. Thank you very much !
Message 6 of 10
(9,851 Views)
Hi again guys,
If I still want to asci input other than changing to HEX mode from front panel, what is it that I'm doing wrong ? VI is attached too.
Thanks in advance.
Message 7 of 10
(9,812 Views)
wrote:
Hi again guys,
First of all, your 255 (or FF) diagram constant (first post) should probably be U8 representation. Notice the red coercion dot?
Second, if you cast your string to a I32, the string must be 4 bytes longs (4 characters) Is it always? Does not make a lot of sense.
The display format of a string is just cosmetic. It does not change the bits.
Message 8 of 10
(9,810 Views)
Sorry, so what is your suggestion ?
Message 9 of 10
(9,805 Views)
I found the answer from one of your 2005 post @altenbach.
Thanks champ !
Here is the link if anyone is looking.
https://forums.ni.com/t5/LabVIEW/Convert-hex-string-to-ascii/td-p/190846
Message 10 of 10
(9,797 Views)
