Integrate a line in a 3D plot.
As you can see in the picture i have a cloud of point of my object. I have found the principal direction of the object thanks to the PCA. I would like to add this line in the graph but it's seem impossibile. I have the slope e and a point of the line.
Message 1 of 8
(3,559 Views)
Please attach (a) the VI (or VIs) that produced this plot and (b) the data set that gets plotted.  I'm a little confused how you plan to plot a line in 3-D space given only two parameters (a point on the line and a "slope with respect to ???").
Message 2 of 8
(3,529 Views)
use several x,y,z cursors drawn on the 3d graph to represent the line?
Message 3 of 8
(3,524 Views)
Thanks for the answer.
Ok, this is the VI.
yes, it's only two parameters beacause i don't care for z data. i mean, i want to plot the line in plane XY. So this way a point and the slope should be enough.
The point is the mean X,Y,Z and the slope is the result of the PCA.
I would like to see that line in the same plot of the cloud of point.
Message 4 of 8
(3,508 Views)
it could be a good idea, but is there a way to set the x,y,z origin from the code?
Message 5 of 8
(3,507 Views)
please attach the missing sub.vi
before uploading,
run your main.vi, so there should be meaningful data in the array, graphs etc.
 click " Make Current Value Default" , then save.
Message 6 of 8
(3,493 Views)
origin in terms of what? in terms of the 3d Surface Plot?
Message 7 of 8
(3,484 Views)
so, I created my own sample data for demonstration...
I don't think so
I'd say this mean will not be in the X,Y plane as Z is very likely to be unequal to 0
what about the line points which are inside your actual 3d point cloud?
Message 8 of 8
(3,472 Views)
