Instrument
I connected Aglient B2901A with my VI under DC model, now I am going to switch to pulse model.
I was wondering beside to change the Setting Command, what else I need to do? Should I modify my code as well?
As long as I installed the driver at first for the instrument, I do not need to install again, is that right?
(2,740 Views)
Accepted by huskerli
If you are using the LabVIEW plug and play drivers there should be no need to install again if you are just switching from the DC model to the Pulse model. Aside from changing the setting command, you would probably need to configure your application using the Configure Pulse.vi
Hopes this helps
Gabriel M.
Product Marketing Engineer - Academic Courseware
(2,675 Views)
