Instrument Driver DP832
Hi All,
I am Pragathi Devaraja working for Panasonic. I am new to all this instruments drivers and LabVIEW so seeking for an help from this forum. We are using instruments RIGOL DP832 and TDK Lambda Gen10-1000 and hence want to install instrument drivers of same. But I am unable to see these series instrument drivers in LabVIEW to install. In this case could you please let me know what should i do to install these drivers?
Waiting for your response.
Pragathi Devaraja
(8,221 Views)
Could anyone please tell me solution for my problem?
I tried using DP1XXX driver for instrument DP800 but facing error. Details of error is posted below. Please look into this and let me know what could be the problem?
Error:
Fehler -1073807339 bei VISA: Lesen in RIGOL DP1000 Series.lvlib:Initialize.vi->Unbenannt 1
VISA:  (Hex 0xBFFF0015) Timeout ist vor Vervollständigung der Operation abgelaufen.
(8,165 Views)
Accepted by topic author pragathi09
I think you are really mixing up the things here. In your first post you wrote about you want to get driver for a Rigol DP832 model. In your second post you say you installed a driver for Rigol models DP1XXX. You see the issue here? Just a guessing, but the driver for models 1XXX might not function with the model DP832.
Other hints: you should also check your cabling, whether it is properly done?
Here I have also found a community driver: http://forums.ni.com/t5/Community-Documents/Rigol-DP832A-Instrument-Driver/ta-p/3512811
Or you can try to use the IVI drivers from the official website: https://www.rigolna.com/products/dc-power-loads/dp800/
(8,162 Views)
Thanks for your answer. I was searching for instrument driver of DP800 but did not find hence tried with DP1XXX driver which seems to be incorrect. Now i will install DP800 driver.
Thanks again.
Pragathi
(8,160 Views)
Hi Pragathi,
  • Download the RIGOL_DP800_Series.zipfrom https://forums.ni.com/t5/Community-Documents/Rigol-DP832A-Instrument-Driver/ta-p/3512811
  • Unzip it & place the folder "RIGOL DP800 Series" inside your LabVIEW INSTR LIB folder (for example, C:\Program Files (x86)\National Instruments\LabVIEW 2016\instr.lib)
  • Mass Compile the folder "RIGOL DP800 Series", if required; meaning, if your LV version is 2014 or later (because the driver was done with LV2013) by selecting it (C:\Program Files (x86)\National Instruments\LabVIEW 2016\instr.lib\RIGOL DP800 Series) through Tools >> Advanced >> Mass Compile), and you are done!
- Partha ( CLD until Oct 2027 🙂 )
(7,907 Views)
The example has one issue when using with german language. A %.; is needed in "Format into string" to get a decimal point. Moreover, the channel line is connected to the wrong input in the "configure Output" at the end.
(4,170 Views)
