Overview
This is an VI Instrument Driver for the Rigol DP832A Power Supply.
Description
This VI Instrument Driver can be fairly easily extended to work for other power supplies within the 8xx series. The ID Query string will need to be updated in Initialize.vi and the channel names will likely need to be modified in the Type Def Channels.ctl. This is modified from the DP1308A VIs from http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=19034
Be aware that not all VIs have been throughly tested. The Example works well along with the VIs specifically used within. The Timer VIs and a few others have not yet been tested so use with caution.
Requirements
Software
This was done with LabView 2013. Not sure how it will work with older versions.
Hardware
Rigol DP832A Power Supply or other power supplies in the 8xx series
Additional Images or Video
Hi There,
I am using Rigol DP831A power supply. This is hooked up to a PC via USB from the USB DEVICE port on the DP831A.
It showed up on my MAX as "USB0::0x1AB1::0x0E11::DP8A161250031::INSTR".
The VI's that you upload (RIGOL_DP800_Series.zip 249 KB) did not work (Error -1073807339 occurred at VISA Read in RIGOL DP800 Series.lvlib:Initialize.vi->RIGOL DP800 Series Output DC Volts.vi).
You mentioned that we have to change the ID Query string on Initialize.vi. I don't think i get it properly.
Could you please let me what are the changes i have to make in which VI's and what the exact string i have to change.
Gayan
Removing VISA CLR didn't solve this problem for me. I changed the *IDN?; to *IDN? and now it doesn't return error reading the ID.
Correction:
By changing the ID query the function works fine except if I run the vi multiple times, it returns error. The solution for this problem is mentioned above by hchang which is removing the VISA clear.
works on LV2017
1. Test using NI MAX -> VISA test panel -> Input/Output -> Query for *IDN?\n
2. If no answer reboot Power Supply (I needed to do so)
3. I've removed VISA CLR as above but maybe it's not necessary...
4. If using DP832 instead of DP832A remove "A" in Initialize "RIGOL TECHNOLOGIES,DP832A" -> "RIGOL TECHNOLOGIES,DP832"
I'm getting the same error code while attempting to use this VI with the LV 2019 evaluation copy on a new Win 10 system with a Rigol DP832 DC power supply. I've changed DP832A to DP832 in the initialize VI and deleted the VISA CLR function from the initialize VI. Does anyone have other tips?
The DP800 series programming manual mentions needing to run "Ultra Sigma" code from Rigol before using LV with the DP832 - is that still necessary?
Does the DP832 need any special manual configuration before using Labview?
Thanks, Mike
