Installing Labview runtime engine 2011
Is it mandatory to uninstall any previous version of the Labview runtime engine before installing the 2011 verstion ?
Thanks.
(3,245 Views)
No, you should actutally keep the older runtime engine installed in case you still have applications that depend on it. The 2011 run time will only support applications built with LabVIEW 2011.
(3,242 Views)
