Installing Labview RT OS 2010
Is there anyway of installing LabVIEW RT OS without using floppy disk drive?
In MAX, it requires floppy disk to create a desktop PC boot disk...
Thanks..
(2,938 Views)
Hi simply_ynan,
Yes, you can.  Since you have LVRT 8.2+, you can create a bootable USB key.  Please see the following KB:
http://digital.ni.com/public.nsf/allkb/04CA96A4A0D7CB778625719A00515831?OpenDocument
It is also a good idea to check that your PC meets the requirements needed to install the RTOS
https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...
Finally, this link will give you instructions on how to install it
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PhCAI&l=en-US
Che T.
(2,918 Views)
Thanks!
I can now communicate the target PC but cannot get its settings and it says "no network adapter can be cound".
I already tried the suggestion stated in https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LgjSAE&l=en-US but to no avail. Also, some options are disabled even I log in as admin.
Thanks...
(2,909 Views)
Hi simply_ynan,
Do you also get a yellow banner that says "MaxServerUnknownException"??  Did you run that software to check to ensure that all of your hardware is compatible?
Che T.
(2,893 Views)
