Installer requires Win 7 on target even if XP serv pack 3 is selected
After the latest update (made with the NI-update service)  to my labview 2014 installation, all installers created with the application builder require Windows 7 Servicepack 1 to be installed on the target machine otherwise it terminates the running of the installer. This happens even if Windows XP service pack 3 is selected as the operating system of the target on the last tab in the installer creater. Very annoying since I can't now build applications for targets running XP. Is there a way to fix this other than reinstalling labview without using the updates?
(4,446 Views)
Accepted by topic author goed99
This topic just came up 5 days ago here.
LabVIEW 2014 installer points to wrong minimum OS
(4,439 Views)
Thanks.
I found that thread 5 minuts ago.
Still annoying to have to go in and change every ini file manually so I hope they fix this.
(4,429 Views)
