Installer issue
Hello everyone I m trying to make installer and successfully done it and i
sucessfully installed in another system which is not having labview.i tried
to run the exe which is showing error as shown in figure. the same exe does
 not create any problem when i run in system with labview. i tried several
times with many modification.but the error does not get rectified.
I have included additional installers like serial.Visa etc.while creating
Plz let me kno what exactly the problem is and what is the solution?
(3,086 Views)
The dll mentioned in the error message is part of LV and should be included automatically as part of the installer. When you build the application, does it get included in that build? By default it gets placed into a subdirectory of the build directory named "data".
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,077 Views)
Yes The dll mentioned in the error message is included automatically When I build the application, in the subdirectory of the build directory named "data".
(3,055 Views)
Hello Mahesh,
You can look this discussion, this can be a solution for your thread.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,046 Views)
You said in your original post that you were building an installer, and then using that installer to put your executable on the new machine. Yes?
After you run the installer on the new computer, there should be a "data" directory in the install folder on the new computer. Do you find the directory, and is the DLL in it?
Mike...
LabVIEW Champion
(3,038 Views)
