Installation not possible
I tried for several days to install properly a LabVIEW version on my PC, however, it fails always. At the first installation there were some error messages which I googled and tried to solve. Also all the time during uninstallation error messages occured and I was not able to delete LabVIEW completely (no uninstalling through control-panel->uninstall program possible). So I delete it manually using removal software (Revo uninstaller Pro, ccleaner). After trying to reinstall it, errors like "Cannot install NI Uninstaller: reason: A higher version of NI Uninstaller is already installed". I deleted some registry keys, after that no error message occur while installing the software. However, installation process in finished within a few seconds and nearly nothing is installed. I have no further ideas how to solve that problem.
From last installation I have attached an error message that occured after the installation of version 2012-fall and the log files from the installation of version 2012-fall and 2011-fall.
I have Win7 Profession SP1, 64bit system.
Thanks for help
(3,235 Views)
Error 2 means memory is full. If you are installing in C then please check whether C is having space or not ?
What processor you are using ?
Please make sure before installing all components of labview is uninstalled. I think when you deleted some coponents are still there as this is not the way to remove the components.
Why dont you have a words with customer executive ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,231 Views)
I have plenty of space in C (>300GB is free).
My processor is an Intel i5-5310M
I tried to remove everything that possible from the drive with the removing software. Under the C drive there is no National Instruments folder left. However, I saw that there are hundreds of registry keys left.
Do you have ideas what could be wrong?
(3,222 Views)
According to microsoft the Windows Registry is a hierarchical database that stores configuration settings and options on Microsoft Windows operating systems. May be that is causing problem.
After uninstallation did you restarted your computer ?
--Ranjeet
(3,203 Views)
Yes, I restarted the computer, but that didn't help. Somehow there must be entries that tell the installer that there was a previous version installed. I think that prevents the installer from reinstalling LabVIEW again. There are hundreds of registry entries left, I think I cannot remove them all manually, that would take hours and most probably I would remove some important registry entry. Also the registry cleaner programs couldn't help me, so I have no idea how to proceed. :-(.
Thanks for your help. Other ideas?
(3,197 Views)
Yes I thinks what is best is call and talk to customer care executiveSmiley Very Happy
--Ranjeet
(3,193 Views)
