File Dialog Box often takes a long time to execute
Hi all
The Labview File Dialog Box Express VI sometimes takes 5 to 10 seconds to execute. On other occasions, it executes in a blink of an eye. Why is that so?
I have tried to use the older Open/Create/Replace File VI as suggested in one of the forum's posts...but it behaves exactly the same way. Another problem is the trimming of the filename, which has also been reported and has NOT YET been solved.
(By the way...Recently, I updated to LV 2012 SP2 by suggestion of the NI Update Manager, only to find out that I was not entitled to this SP (which apparently only includes bug fixes) and I will have to roll back to LV 2012. Still,  in the evaluation version I can see that the bug is not fixed. Labview must have a lot of serious bugs for NI to ask for a paid bug fix, in which some bugs remain after having been reported a long time ago..well...)
What worries me now is that intermittent lag in the execution of the File Dialog (such a basic basic function of a program...). Anyone have any idea about this? The support menu said "Ask an engineer"...any of the NI engineers has any suggestion?
Regards
Helder
Message 1 of 8
(5,301 Views)
This could be due to disconnected network drives or unavailable files causing timeouts. Could this be the case? The ui thread must be idle to show the file dialogue. Could another part of the application be blocking the ui thread at the time you call this dialogue? Im on a mobile at the moment so I can't see the vi you posted.
Message 2 of 8
(5,290 Views)
The file dialog is provided by the OS, so if it is slow it is not LabVIEW's fault.
What kind of computer do you have? Is this a laptop that spins down the HD to save power? In this case it needs to wait for the HD to spin up. (You can change the windows power profile or you can spend more money and get an SSD).
Are you very low on memory?
Does your LabVIEW program waste 100% CPU in parallel doing nothing due to bad coding?
Are you pointing to a location that has millions of files?
Are you pointing to a network location?
What problem is that? Can you elaborate? There is a known bug in the windows dialog box that sometimes the pre-filled file names are shifted and not fully visible. This is a windows bug documented by Microsoft and LabVIEW has no control over it. It is not NIs job to fix OS problems.
@helder wrote:
Hi all
Patches are included, service packs are not included. I think this is well documented. Most users are on SSP, this way you are always entitled to the newest version.
As with anything else, software has bugs. It is impossible to test a huge, complex system like LabVIEW under all scenarios. The possible number of combinations of hardware and other installed software on any particular computer probably exceeds the number of atoms in the universe. It is actually amazing how few bugs there are and how well it works. What "bug" are you talking about? Bugs are prioritized according to rules. Critical bugs are typically fixed very quickly. A cosmetic issue that only affects you and nobody else will take longer or might not even get fixed. Are you talking about a confirmed bug that could be reproduced by NI? Do you have a CAR#?
That sentence makes no sense! Why would the number of serious bugs depend on the cost of upgrading?? You are just rambling here....
In an ideal world, NI would have an unlimited number of programmers that can work 24/7 to immediately fix any discovered bug. This would only be possible if all users are willing to pay an unlimited amount of money for the software. As I mentioned, bug fixes are free in the form of patches, and they come out regularly. Service packs include new features and are not free.
Message 3 of 8
(5,285 Views)
As the other poster mentioned, you most likely have issue with network connection (setting of your ethernet or wifi) and nothing to do with LabVIEW (in fact I'm thinking that it has nothing to do with the operating system either, but with setting of your ethernet connection or with things like SAMBA/etc server settings). In case of such network issues, EVEN IF you're simply trying to use the file dialog box to access some local file, the file-system on your operating system will try to first establish connections with your network drives even if you don't need them).
Easiest way to debug this would be to see if you can remove all network drives mappings and then use files dialog manager (also make sure that your computer hard-drives are not put to sleep all the time as even that would cause delay since hard-drives would have to spin up first.)  If the above fixes your lag issue then your fix is not in LabVIEW but in your network settings.  Alternately you could run the same vi on a different computer and see how it behaves.  LabVIEW has some bugs but not the types you're mentioning, and I haven't heard of current users getting charged for fixing LabVIEW bugs.  If you are told that you'd have to pay to have your issues fixed (also judging by what you've mentioned so far), I'm quite certain that they know that your problem is outside LabVIEW.
-DP
BatchTest Corp.
NI Alliance Partner
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
Message 4 of 8
(5,268 Views)
First of all: Thank you very much for the objective answer. I suppose that yor actually ARE a NI engineer, as I had hoped for.
lease find my comments above (helder---------------------)
helder:---------------------------------------
I understand that the File Dialog is provided by the OS. But I have other applications on my PC and this doesn't happen - just in Labview. Sorry! And sometimes it
doesn't happen. Every 10 times I open the File dialog Box, 5 times it takes long and 5 times it is immediate.
(I am not low on memory, my coding is not bad>-look at the VI I sent, it just contains the fragment which uses the File Dialog Box and it behaves the same way! I am pointing to the same location that the other applications point to, I am not pointing to a network location, the PC is not spinning the disk down, etc etc.)
But yes, I will try it on another PC
(There was another post on the forum on this issue, but can't seem to find it now, just find my own post )
I attach a video demo of what happens.
helder:-------------------------------------------
Of course you can't fix the OS.
If it is a windows bug, we will have to live with it.
A previous post on your forum did not provide me with that information (http://forums.ni.com/t5/LabVIEW/File-dialog-trimming-the-default-name/td-p/2189874). The fact that it is a windows bug was not mentioned there.
@helder wrote:
Hi all
I was referring to the file-name-shifting-cosmetic-bug that the October-2012 post had indicated. But if it is a Windows-bug, NI does not have any responsibility, of
course.
Regarding the bugs, of course they are unavoidable.
"....include new features"..????
---->>From http://www.ni.com/labview/release-details/
"LabVIEW 2012 Service Pack 1 is an exclusive update to LabVIEW 2012 for NI Standard Service Program (SSP) customers. There are no new product features introduced in service pack releases; instead, these releases provide bug fixes and improved stability for LabVIEW 2012. For a list of these bug fixes, click here."
No new features, just bug fixes!"
Moreover: If it isn't free, it shouldn' have let me update if I am not a SSP costumer.
Now I have a 45 days evaluation version. After that, I have to uninstall and reinstall everything.That takes some time and effort.
If there is a more direct way of rolling back t the previous version, please let me know.
Thank you
Message 5 of 8
(5,222 Views)
BTC_admin escreveu:
-DP
BatchTest Corp.
NI Alliance Partner
Thank you DP
Actually,the FileDilog Box does come up quickly every time , but half of the times it takes a long time to return after OK or cancel.
I have attached a video demo in the reply to the other post, but probably it is too large (I don't see it in the post)
So here's a link to it:
https://dl.dropboxusercontent.com/u/26967896/FileDialogDemo.swf
Regarding SP's and bug fixes...I have already commented this in the other reply.
I am just angry that the Updater suggested me to update to a service pack that I didn't know I had to pay for (how should I know...It is a SERVICE PACK not a new version/release). And now I have to uninstall it and reinstall the older version....
Regards
Helder
Message 6 of 8
(5,216 Views)
I see what you mean - have you tried your VI on a different computer? (It works fine on my windows laptop as well as on a MacPro computer here.)
It almost looks like your computer needs more time to find some files (maybe not cached) versus some other files (which seem to be cached) - more of a hard-drive thing. Have you had lag issue with any other software on your computer (one thing you could do is try to opening those same excel files with Microsoft Excel repeatedly and see if it causes any lag.  This still does not look like something that requires patch or a new version of LabVIEW as it looks outside LabVIEW (otherwise it wouldn't work fine in all other computers such as two of mine and I believe other posters also tried it out on their computer.)
You could also try this without using file dialog express vi to see if it makes any difference... (if it works fine without using that express VI then things might be because of some LabVIEW bug, but it really doesn't look that way).
-DP
Message 7 of 8
(5,204 Views)
Thank you for your suggestions. I will try everything out.
Regards!
Helder
Message 8 of 8
(5,168 Views)
