Installation memory error on Windows 10
Attempting to install LabView 2018 (old version necessary for backwards compatibility reasons) on my very new Microsoft Surface running Windows 10. When I try to run the installer, I agree to let the installer make changes, and then immediately receive a pop-up window that says, "SETUP ERROR: Not enough memory resources are available to process this command."
Hard drive has 115 GB free, so I'm assuming it's a RAM problem. After restarting and closing all apps and as many background processes as possible, I'm seeing ~4.5 GB of free memory in the task manager--- but still getting the same error.
Has anyone had a similar problem on install?
(1,667 Views)
What kind of processor?
Bill
CLD
(Mid-Level minion.)
(1,627 Views)
Please specify the actual model of the Surface. LabVIEW is a Win32 application and only will work (and install) on a computer with the full Windows version and a Intel x86/64 CPU. Some of the Surface models are ARM based and run the Windows RT version (or even Android, although that is obviously not the problem here).
Rolf Kalbermatter  My Blog
(1,612 Views)
