Install error for 5.1.1 RTE
I am trying to install the Run Time Engine for 5.1 that I downloaded from NI to run an executable from Analog Devices for an evaluation board; however every time I try to install the RTE I get an error stating "Cannot find LabView 5.0".  I have another computer where somehow I installed I believe LabView 8, uninstalled it, installed the RTE and it works without any issues.  However I've been unsuccesful in duplicating this on any other machine.
Does anyone have any suggestions on how I can get the installer to actually install the RTE?
Thanks.
- Eric
(2,710 Views)
Hey Eric,
I would just check all versions of the different software on your computer to make sure you have no conflicts. You can either look in MAX or you can llok in add/remove programs. You should also be able to check what compatible versions you need on our website at ni.com by searching.
I know this isn't a specific solution, but hopefully it can get you on the right foot.
Chris Van Horn
(2,687 Views)
