Install LabVIEW on Windows 7 X64
I'm trying to install LabVIEW from NI Developer Suite Third Quarter 2009 on Windows 7 X64 machine. The install program terminates with an unexpected error. I can install LabWindows/CVI from the same DVDs onto this machine.
(3,772 Views)
Accepted by Ed Fitzgerald
I solved this myself. The solution is to run setup.exe on the installation disk is Windows Vista compatibility mode.
(3,750 Views)
I'm adding my own experience in installing LabVIEW 2009 onto Windows 7 (64 bit) in case it helps anyone else, but in fact there's no magic bullet for the problems I had, I did it the hard way.
I saw no error messages at all, just that when the installer wanted DVD no.2, the DVD drive seemed to disappear.  Cursor remained as Windows 7 "timer donut", could do very little with PC except "master reset".
I tried:
  • A different DVD drive
  • Upgrading to Windows 7 sp1
  • Compatibility mode for Vista (as suggested above)
In the end I just copied the contents of the 3 install DVDs onto my hard disk.  I named the directories as the DVD labels, and was impressed that the installer found all the parts automatically.  Until it got to the Device Drivers DVD, which I had forgotten to copy, but mercifully at that stage I could browse to the DVD drive.  No special compatibility settings used, but I did run setup.exe "as administrator".
I'll put this down as a Windows 7 bug (and maybe specific to my hardware ?) rather than an NI problem.
Along the way, as part of the sp1 upgrade, I got MS IE9, another great way to drop one's productivity Smiley Mad (certainly made posting to this forum impossible, this done on a different machine).
(3,264 Views)
