Install LabVIEW NXG on cDAQ-9132 embedded controller
Is it possible to upgrade my cDAQ 9132 embedded Windows 7 controller to Windows 10 and install LabVIEW NXG?
(3,333 Views)
Accepted by topic author sfrosty
Hi sfrosty
This device does not support Windows 10, you can try to make the upgrade but it is not guaranteed that it will work. Additionally, the controller of the cDAQ-9132 has 2 GB of system memory and if you look at the readme of LabVIEW NXG, it requires 4GB of RAM memory.
Astromaut
(3,280 Views)
This is Cesar from NI. I'm going to be the engineer assisting you with the questions regarding the compatibility of LabVIEW NXG with a cDAQ-132 controller.
The readme file of LabVIEW NXG 5.0 indicates that it only supports 64-bit Operating Systems. Unfortunately, our cDAQ controllers use a 32-bit version for the Operating System.
Additionally to that, the NI-DAQmx driver support files for LabVIEW NXG doesn't include support for cDAQ controllers. The next document shows a table of all the hardware that is compatible with LabVIEW NXG. There is a note at the beginning of the table that mentions the support for cDAQ controllers.
C Series Module and CompactDAQ or CompactRIO Controller Compatibility with LabVIEW NXG
https://www.ni.com/en-us/support/documentation/compatibility/20/c-series-module-and-compactrio-controller-compatibility-with-lab.html
(2,752 Views)
