How Can I group Objects in the Front Panel
Hello, I want to group objects for example five led Indicator if I want to move the five led, I can move the five led as a Group, and not only move an individual led for one.
Thanks you.
(4,659 Views)
You can put them in a cluster.
Or you could lock the 5 into a group using the drop down on the toolbar that looks like a blue and yellow arrow circling each other.
(4,651 Views)
Accepted by topic author Roger125
You can group the objecte that you want by :
1. selecting the object .
2.select Reorder.
3.click group.
 Best Regard
(4,649 Views)
Select (lasso) the objects.  From the "reorder" drop-down button, select "Group"
(4,645 Views)
Thank you for your answer, I can use the tool Group.
Best Regard
(4,594 Views)
