Install LabVIEW DSP Module on Labview 2009 Professional
I have LabVIEW 2009 professional and i am trying to install LabVIEW DSP Module on it. I have LabVIEW DSP Module 8.6 and I think it is the final version. However, when i was trying to install it, it is said that you should have LabVIEW 8.6 on your system.
What should I do?
(5,387 Views)
Accepted by Orod
Hello Orod,
That is correct, to run the LabVIEW DSP 8.6 module, you need to have LabVIEW 8.6, which can be installed and run in parallel with LabVIEW 2009. I apologize for the inconvenience, but 8.6 is the last version of that module, so you'll need to purchase LabVIEW 8.6 to use it.
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(5,370 Views)
LabVIEW 2011 has released and there is no new module for LabVIEW DSP since LV8.6!!
Is there any plan to release a new LabVIEW DSP Module?
Is there any LabVIEW kit or Module can handle DSK6713 except LV DSP Module?
Thanks in advance & regards,
WALID
(5,323 Views)
Hey wedo,
We do not know when and if an update to this module will be available I did some research on other modules supporting the DSK6713  and it seems like your best option is to use the LabVIEW DSP Module.
Kevin Fort
Principal Software Engineer
NI
(5,313 Views)
