Inserting points for the simulate arbitrary express vi on the front panel
I am not familiar with chunks and i couldn't really find something on the internet about it. Can you explain something about chunks or give a link where i can find some explanation about it?
Message 21 of 28
(944 Views)
A chunk is just slang for 'more than one sample'.
Your DAQ AO is now set to output one value per cycle.
You can set it to 1D Array, and output 100 or 1000 samples at once. Of course you can't use auto indexing anymore. You can use the iterator i, and multiply it with the size. Then use Array subset to get data from index iXn and length n. Or put the array in a shift register and use Delete From Array to get the sub arrays from the beginning, and pass the remaining array to the next iteration. This will be CPU hungry if the array is big (megabytes).
This will let the HW determine the output rate. If you don't supply the next chunk in time, you'll get an error. But this timing isn't very strict. The DAQmx has a buffer, and you can add chunks to it. As long as the buffer it's not full or empty, DAQmx will output the data to the hardware.
Message 22 of 28
(941 Views)
Okay i will try that! Thanks
Message 23 of 28
(939 Views)
I think i got it, you write with the subset array a part of the array before the loop to the DAQmx. But how do you control the output rate with the hardware? The hardware i am using is a simulated NI cDAQ-9178 with a simulated NI9263 module.
Message 24 of 28
(934 Views)
I'm not that much into DAQ, but (simulated) devices that support buffered output define their frequency in the task. This can be in Max or in LabVIEW (if you create a task in LabVIEW). So for you the easiest way would be to change it in Max, where the task is defined.
Message 25 of 28
(925 Views)
I already tried some things but I close this topi because i already have the solution for my first question so thanks!!!!
Message 26 of 28
(905 Views)
You're welcome. Hope to meet you at a Dutch LabVIEW user event someday, if\when things are back to normal.
Message 27 of 28
(895 Views)
I will look out to the event! 🙂
Message 28 of 28
(889 Views)
