Insert value in table
Hi everybody
I have a problem with the table block.
I want each loop , The data will insert to table follow columns, not follow rows.
Best regards
Van Phu
Message 1 of 8
(8,636 Views)
Van Phu,
A table is just a 2D array of strings.  So just convert the numeric array to strings.
Lynn
Message 2 of 8
(8,633 Views)
Hi
Best regards
Van Phu
Message 3 of 8
(8,612 Views)
Van Phu,
I do not understand exactly what you want.  You want to duplicate column 1 and create a column 2 with the duplicate?  If your array gets large this seems wastefull of memory and processing time.
Try this.
Lynn
Message 4 of 8
(8,606 Views)
If you want to flip columns and rows just transpose the array, as shown in the last post from Lynn.
Message 5 of 8
(8,601 Views)
Dear everybody,
As in the example below.
In the example I used 3 case,
Case 1. The value will show on 2 columns
Case 2: The value will show on 4 columns
Now I don't want use many case so.
I want only use for loop to.
Loop 1: The value will show on 2 columns
loop 2 : The value will show on 4 columns.
Best regards
Van Phu
Message 6 of 8
(8,568 Views)
Vanphu,
     I'm curious as to why you're using dynamic data for your table of doubles. I think the way you want to approach this would be to use an array of strings. You would then insert your random numbers into the string array and pass the array to the next iteration of the for loop using a shift register. Hope this helps.
Ryan Sparks
Message 7 of 8
(8,546 Views)
Hi Ryan_S,
Thahk you very much.
Best regards
Van Phu
Message 8 of 8
(8,507 Views)
