Hi
I'm trying to pass loop index value from sub vi to progress bar in main vi(without interrupting the measurement in the loop) !
how can I make it ?
I'm working with LV 6.0.
T.U
Message 1 of 19
(5,868 Views)
You could use a global variable. Write the value from the loop index to the variable in the loop and then read the value from the variable to the progress bar in the main vi.
Message 2 of 19
(5,868 Views)
I'ts not working with Global var.
the Global var. can not be read at the loop time.
Regards
Message 4 of 19
(5,868 Views)
Did you change the variable to read? You can do this by right clicking on the variable and selecting "Change to read" from the pop-up menu.
Message 5 of 19
(5,868 Views)
I'ts still not work.
Message 7 of 19
(5,868 Views)
Put the reading of the global variable in a loop separate from the loop that called the subVI.
Message 6 of 19
(5,868 Views)
I think the only way is to use a global variable.
Have the subVI write too this global and read it in the VI.
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 19
(5,868 Views)
Hi Mor,
You could try Notifiers to pass the data. To pass a number using a
notifier you have to flatten to a string and then unflaten afterwards.
Since you are using LV6 you could access the indicators 'value'
reference node from the loop.
Another way is to use the built in datasocket connection in your
indicators.
To make all of this work you have to have a running loop in your
progress bar VI.
Tim
Mor wrote:
> Hi
> how can I make it ?
> T.U
Message 8 of 19
(5,868 Views)
Hi, I think the only way is to use a global variable.Have the subVI write too this global and read it in the VI.RegardsRay Farmer
Message 9 of 19
(5,163 Views)
The Global should work, but it will not update your progress bar during a measurement unless your progress bar is actually inside the measurement loop.  Attaching your VI would be a great help.  Instead of a global, I would actually use a "functional global" (search the forum - you'll find lots of info) because you can get better control over the sequence of execution.
Michael Tracy
Synergy Microwave
(still using LV7.1)
Message 10 of 19
(5,158 Views)
