Insert rows to excel spreadsheet using LabVIEW
Hi
is it possible to get each row of a table in a a different worksheet, for example the 1st row in the 1st worksheet and so on using just EXCEL ADVANCED VIs.
Message 1 of 20
(10,154 Views)
any suggestion
Message 2 of 20
(10,132 Views)
Hello....
I think you want to ask about to add something in a row of excel sheet...If I am right then here its a very easy task provided by labview functions shown in below .vi
Message 3 of 20
(10,116 Views)
thanks
i will take a look in your Vi,if it wil help me,because i'm looking to get each row of the same table in a different worksheet of the same excel workbook
Message 4 of 20
(10,087 Views)
Hi achfire,
If you want some more control (like creating worksheets), take a look at this example:
https://decibel.ni.com/content/docs/DOC-20014
As for getting each row into a new worksheet, tables auto-index at for loop boundaries just like arrays do. On the above example, add a for loop so that you are creating a new sheet, indexing your table by row at the for loop boundary, and writing that row's data to the table.
Let us know if you run into more issues!
Best,
David R
Systems Engineer
Message 5 of 20
(10,055 Views)
2.pngwhere exactly to add the loop,because i already use it but i didn't succed,maybe i missed something
Message 6 of 20
(10,051 Views)
Accepted by achfire
Hey achfire,
I made a few edits to your code, and it appears to work now. Generally speaking, we don't want to open and close references or files within a loop. Instead we can open the file once, read/write to it in our loop, and then save/close it when finished. I also removed the index array function, as for loops can auto-index at loop bounaries. (This also prevents us from having to wire a number of iterations into the "N" terminal.)
Let me know if this helps!
David R
Systems Engineer
Message 7 of 20
(10,019 Views)
What is the purpose of the 1-D string array constant that is empty?  It looks like it is just there to turn the 1-D array into a 1 row 2-D array.  If so, you just need the build array function with only one input and get rid of the empty string array constant.
Message 8 of 20
(10,011 Views)
Roohcifer
ii doesn't work because i have labview 2012
Message 9 of 20
(10,006 Views)
Hi achfire,
Try modifying your code to look like this:
David R
Systems Engineer
Message 10 of 20
(9,992 Views)
