Insane Object Error
I get an Insane Object error. I have tried to remove newly created wires/tunnels and also tried to copy/paste the code into a new vi, with the same result. Does anyone have a suggestion how to resolve this?
Roger
(3,508 Views)
Hi Roger
Did you already search the forums? There are lots of threads about insane objects - these are just three of them:
http://forums.ni.com/ni/board/message?board.id=170&message.id=24302&query.id=417935#M24302
http://forums.ni.com/ni/board/message?board.id=170&message.id=209203&query.id=417949#M209203
http://forums.ni.com/ni/board/message?board.id=170&message.id=140714&query.id=417973#M140714
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,499 Views)
You don't happen to have a version control system? If so, check out the latest version without that problem and redo the changes.
Without that, I'd suggest copying the block diagram section by section in a new VI and saving the VI after each copy process.
Hope this helps,
Daniel
(3,497 Views)
Thank you very much, everything is solved now. I found the wire causing this error!
Roger
(3,480 Views)
(3,479 Views)
