Initial Settings
Hi guys,
I was wondering how do i preset my settings when there is at least 2 options. For example: two buttons - 1) Linear Motion and 2) Circular motion. How do i set the the initial setting will be clicked onto the linear right from the start? Thank you in advance. Cheers.
Best Regards,
Scott.
(2,749 Views)
What settings are you talking about?  "linear motion" and "circular motion" sound pretty specific to some application or module you are using, but you haven't given any information.  Please fill in all the missing details.
(2,733 Views)
Accepted by topic author Sena_Scott
Are you asking how to make sure that a particular set of Control values are used (by default) when your program starts?  If so, set up the Front Panel as you want it to look, go to the Edit menu, and click "Make Current Values Default".
(2,725 Views)
