Index through cluster to change value
Accepted by topic author TeddyLu
@TeddyLu wrote:
I have over 20 boolean controls that need to be reset back to default state (off). I've put all them into a cluster and then set to an array and change each one through a for loop,
What you need to do instead is combining also the controls into a cluster (you can make the cluster container transparent so it's not even visible) . Now you only have one terminal instead of 20. To reset, just write back to a local variables of that cluster.
Here's a quick example (LV2013).
Message 11 of 13
(58,770 Views)
hi TeddyLu,
just wanted to add this
if you only want reinitialize to default value
you can use reinitialize to default invoke node
bp
Message 12 of 13
(58,742 Views)
Yes, Local Variables gets replaced with Reference property nodes in Snippets.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(58,729 Views)
