XNET CAN Create Session error 0xBFF63001
I develop an application to use 9 "NI PCI-8512" CAN Cards with LabView 2015, NI-XNET 17.0.1 under Windows 7.
Note: I use only "XNET Create Session (Frame Input Stream).vi" and "XNET Create Session (Frame Output Stream).vi" functions for each CAN port.
An error "XNET CAN Create Session error 0xBFF63001 " appears randomly on CAN initialization for one or more cards and I can't properly initialize the 9 CAN cards.
After an initialization error, the CAN ports in error are renamed in NI-MAX to "CAN-1" and I have to restart the PC to get correct CAN names.
I attached a screenshot of my test program, as well as the result of the initialization of the 9 CAN cards (cards 5, 7 and 8 in error in this example).
Do anyone have any idea to solve the CAN initialization problem?
Christophe
(5,100 Views)
Any chance you can upload your actual VIs instead of just screenshots?
Also, are there any hints about what is happening in %LOCALAPPDATA%\National Instruments\NI-XNET\log\niXntErr.log?
(5,084 Views)
You can find in attached files my CAN tests vi's and error logs.
Christophe
(5,076 Views)
Accepted by topic author Microtec
Hi Christophe,
There is a hard limit : Maximum of 8 Frame Input Stream sessions that can be created and active at any one time.
You could find the information in this KB :
NI-XNET Error -1074384878: Maximum Number of Frames Has Been Exceeded
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7kHSAS
If you initialize only 8 CAN cards, does the error still exist ?
Eloise
NI France
(5,045 Views)
Hi Eloise,
Thank you very much for this information, this explains my CAN "Input Stream Session" problem.
Indeed, I initialize two input sessions for each CAN card and the problem often happens after the fourth card...
Best Regards,
Christophe
(5,032 Views)
