Index the array and also should I use variant?
Please see the attached document for question and VI for correction. 🙂 Thank you.
Message Edited by Amy222000 on 03-29-2005 03:41 PM
Message Edited by Amy222000 on 03-29-2005 03:42 PM
(2,862 Views)
Message Edited by Amy222000 on 03-29-2005 03:43 PM
(2,855 Views)
Hi Amy,
Could you please post your subVI's Read 2D String from Excel.vi and sub_match_1_t emp.vi as well?
Shakhina P.
Applications Engineer
NI
(2,824 Views)
Hina,
I don't know if this Vi is going to work because it has some sub vi's and I don't know how can I save it as a library files. If you tell me I can send you then. Thank you.
Message Edited by Amy222000 on 03-31-2005 11:08 AM
(2,813 Views)
I think I found a way to save as a library file. So, attaching as library files which ever works for you take it. Thank you.
Message Edited by Amy222000 on 03-31-2005 11:21 AM
(2,807 Views)
I'm not sure what you are trying to do exactly, but here is a simpler VI that should give you an idea. For simplicity, I've used an existing transposed 2D array. Let me know if you have any questions about this.
Good luck with your project!
Shakhina P.
NI
(2,783 Views)
