Index array question
Hi everyone,
I know that I can use a reshape array to convert a 2D to 1D.
But I'm curious to knew how come when I wire a 2D array into an index array and there's no constant for the index inputs, the output comes out as a 1D array?
How does it work in this case? could someone please explain this to me?
(3,173 Views)
Hi LHX,
IndexArray defaults to index the first row of a 2D-array as can be seen by it's non-filled 2nd index input:
(3,168 Views)
Accepted by topic author LHX
Index Array functions always returns the element or subarray of n-dimension array at index. By default, if you do not wire any index input terminals, the first subarray indexes row 0, the second subarray indexes row 1, and so on.
Nghtcwrlr
(3,166 Views)
