Index array function
Can you send your code?
Message 11 of 15
(1,897 Views)
You are not by chance using a U8 to specify the number are you?
Ben
Message 12 of 15
(1,885 Views)
This is what I can generate. When setting 257 index inputs to be generated, I get Index Array finction with 1 index input.
Message 13 of 15
(1,842 Views)
No, I am using the default I32.
There is another cause for this problem.
Message 14 of 15
(1,839 Views)
I found the solution to my problem.
When I wanted to generate Index Array function with 257 index inputs in the generation code I set the number of Chunks to add = 256, but instead the number of indexes had to be = 256.
Now everything works! Again LabVIEW proved to be great environment!
Message 15 of 15
(1,824 Views)
