Incrementing a variable based on the condition
 Yes, you are right. My mistake, sorry. For example, if I want to exit a loop:
int counter; //it is my global value
for(int i = 0; i < dataValue.size; i++)
   if(dataValue == randomValue)
     counter++;
     if(counter  == 2)
        break;
   }else{
    //do nothing
 So in that case, my loop will not be executed if my counter reaches 2. That's exactly what I want to implement in Labview. So can I create another comparison then connect it stop button ?
Thanks for the help
Message 11 of 14
(1,217 Views)
 Thanks for the answer. Yes, it worked. I would like to iterate my for loop and exit if the condition met. For example, if I want to exit a loop:
     counter++;
     if(counter  == 2)
        break;
   }else{
    //do nothing
Thanks for the help
Message 12 of 14
(1,213 Views)
Yes. Do a comparison with your threshold value, then wire the output to an OR node. The other operator of the OR must be the Stop button.
Wire the output of the OR to the conditional terminal.
Paolo
Message 13 of 14
(1,212 Views)
Accepted by topic author aybarskizilay
@aybarskizilay wrote:
 So in that case, my loop will not be executed if my counter reaches 2. That's exactly what I want to implement in LabVIEW. So can I create another comparison then connect it stop button ?
Learn Boolean Logic.
Message 14 of 14
(1,198 Views)
