Increment/Decrement buttons, eternal banishment
Besides toggling the visibility property by hand, every time I drop a numeric control down. Is there a vi or project property somewhere?
Message 1 of 8
(3,779 Views)
Accepted by Corelab
You can make a new .ctl file which has them hidden already. You can also use VI scripting to hide them. I use the "align panel" quick drop function a lot which hides them by default.
Message 2 of 8
(3,758 Views)
Ooooh.  I like (and never knew about) the Align Panel Quickdrop!  Will save a lot of clicking around ...
Message 3 of 8
(3,738 Views)
Especially the enum.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(3,732 Views)
Though, why would you want to drop down hidden indicators? If there are several, group them in a cluster or a Tab control and you can hide all at once by hiding the cluster or simply changing tab. I assume/hope you're not using the indicators as data containers, that's bad practice.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(3,612 Views)
/Y
The OP is referring to the Increment/Decrement buttons that are attached to numeric controls by default.  Yes, you have to infer this from the subject.  I also dislike the buttons and remove it from all of my VIs.  I might also look at that QD Plugin mentioned earlier.
Message 6 of 8
(3,586 Views)
Ah, i missed the button part and assumed it was the full control/indicator.
Yes, i often hide those buttons also. I haven't thought about making it a custom control though, that's a nice workaround.
/Y
Qestit Systems
Message 7 of 8
(3,546 Views)
I mostly use controls from System palette: here my users expect those up/down buttons as are also used in any other tool/software they use…
Message 8 of 8
(3,539 Views)
