Increasing the size of Dialog Checkbox!
  I am trying to resize the checkbox control.
Matt, I tried to links that you posted but the second one (How Do I make a Resizable Dialog Checkbox Control) seems to be a bad link now.
  Why isn't there a checkbox control inthe "modern"control palette?  I found it in the "classic" and "system" palettes.  Neither one allows me to customize the size, and the button size property nodes result in an error.
  I do not need to change the size during run time, I just need a larger checkbox for my touch panel application so that it is not impossible to select!
Any help would be greatly appreciated,
Rebecca
Rebecca Abbott
Serica Technologies, Inc.
Message 11 of 12
(1,168 Views)
Hi rabbott,
You can customize boolean control very easily in the control editor (right click advanced >>> customize).
All of the images (there are four, T, F, T>F, F>T) can be replaced with your own so you can make a check box as big as you need by import your own images.
I hope that helps,
Ben
Message 12 of 12
(1,154 Views)
