cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Increasing the size of Dialog Checkbox!
This is a silly question really, but I would like to increase the size of dialog checkbox (Boolean). Despite various attempts, I have not been able to do so. Can this be done at all? (I've noticed that it is possible to programmatically change the button size through property node, but I'd prefer to change them "manually"!)
Please help!
0 kudos
Mensaje 1 de 12
6.549 Vistas
1. Place a dialog checkbox on the front panel
2. Right-click on the checkbox
3. Goto "Advanced"
4. Select "Customize.."
5. Click the "Edit/ Customize Mode" button (TOOL button left on the toolbar)
6. Edit the dialog checkbox (it is now ungrouped and outlined)
7. You will be prompted whether or not to save/ replace the original control
hope this helps! (Attached in LV6.0.2)
ian.f k
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Descargar todos
Mensaje 2 de 12
6.547 Vistas
Thanks!!! This is working GREAT!!!
0 kudos
Mensaje 3 de 12
6.547 Vistas
My pleasure 🙂
Ian F
依恩与LabVIEW
0 kudos
Mensaje 4 de 12
6.547 Vistas
I've been trying this solution.
And it doesn't seem to work.
When I change the size everything looks fine.
Next I can copy paste it into my actual vi, no problem.
But if I close the .ctl file, the checkbox is resized back to it's former small self.
I've tried saving the .ctl and than inserting the saved .ctl, but same problem, it keeps resizing back to it's original shape, even though the accompanying tet does not.
Any suggestions?
0 kudos
Mensaje 5 de 12
6.547 Vistas
Sorry for the late reply.... been 2 busy lately 😛
This doesn't seems to work in LabVIEW 7.0 and (perhaps) above.
It worked in LabVIEW 6.1
Cheers!
ian
Ian F
依恩与LabVIEW
0 kudos
Mensaje 6 de 12
6.547 Vistas
Does not work in LV7.1 either (however, in newer versions it is easier to use the "Set h and w" from the resize toolbutton). Changing the size via the property node does not work either. Quite irritating.
- Martin
0 kudos
Mensaje 7 de 12
6.506 Vistas
In LV 7.1.1, I have tried using the resize tool and it does not work. I can change the h & W numbers but when I click the apply button, nothing happens. I have two checkboxes and I cannot highlite any of them in the list on the resize window. This needs to be fixed.
- tbob
Inventor of the WORM Global
0 kudos
Mensaje 8 de 12
6.493 Vistas
Please see the following KnowledgeBases for more information on this issue.
Why Can't I Customize a Dialog Control?
How Do I Make a Resizable Dialog Checkbox Control?
Please let me know if you have any questions.
Mensaje 9 de 12
6.466 Vistas
Super, thanks!
- Skinny
0 kudos
Mensaje 10 de 12
6.448 Vistas
