Increase ethercat sample rate
Hi
I have a HBM TIM-EC etherCAT module.
I get this error when I try to sample with 20 kHz.
I have tried to increase the percentage to 55, but I'm not able to sample faster than 15.38 kHz with a scan engine setting of 65 micro sec.
Is there someone who has an solution?
(2,598 Views)
And when I set the scan engine setting to 50 micro sec the attached error shows
(2,589 Views)
I would let you know that NI EtherCAT doesn't support the higher scan rate. I suggest that you decrease the scan rate and test again. Thanks!
(2,560 Views)
