Incompatible VI server protocol
Does anyone know if there is a incompatible issue between labVIEW 5.0
and 6i when using the VI server?
I've configured my server on a machine running labVIEW 5.0 and get
the following error when opening an application reference on a machine
with 6i
Error code 1037 incompatible VI server protocol version.
Mike
(3,527 Views)
Mike,
Though I don't know for sure because I didn't develop LabVIEW, it only makes sense to me that VI Server can only work with the version of LabVIEW VIs for which it was written. I recommend upgrading your older machine, or at least, recompiling all of your VIs in the newer version of LabVIEW.
Basically, to answer your question: Yes, there is a compatability issue between the two versions. I'm not sure what you are trying to do. If you could provide a more detailed explanation, perhaps someone can stir you in the right direction to solve your problem.
(3,527 Views)
> with 6i
That is exactly what the error means. Major efforts are made to keep
the protocol compatible, but the initial protocol had a few problems and
so later versions of LV are compatible with one another, but are not
compatible with the older one. I'm not positive, but I believe there
are only two version of the protocol.
Greg McKaskle
(3,527 Views)
Greg,
Thank you for your reply,
Is there any alternatives? I try to explain what I want to do and
maybe you can offer a suggestion
I'm running labVIEW 5.0 on an old P133 machine with very specialized
hardware. It's been running for 3 years and I don't want to upgrade. I
also have a new P4 1.5Ghz machine that runs labVIEW 6i and all the
user interface screen for a test bed. Basically, I want to control my
specialized hardware on the machine running 5.0 with my new machine
running 6i.
It would be very unfortunate if I could do something as simple as
transferring data from one machine to an other.
Thanks Again,
Mike
Greg McKaskle wrote in message news:<3C8EC55E.70307@austin.rr.com>...
> > with 6i
> Greg McKaskle
(3,527 Views)
> running 6i.
The protocol only affects the VI server, not the rest of the networking
tools. If the data you want to transfer is relatively simple, you can
flatten
it into a packet, and write them on the one computer and read on
the other.
Greg McKaskle
(3,527 Views)
