In which layer does the bluetooch function work?
hi, I am trying to make something similar to you.. I need actually to send file from Pocket PC to desktop computer, so this means that I have to make a BT PushFile.vi  for a PDA and a BT Pull Fille.vi for a desktop computer.. How did you manage to do your .vi? Bluetooth is totally knew for me, I was performing only data acquisition in Labview so far...
I have succeeded so far to perform sending a file via Bluetooth serial port, but it lasts to long:-( My files are around 1MB..
What kind of a BT Dongle do you have? Maybe that's one of catches.. I have MSI BT Stick, which originally has Widcomm driver, not supported from Microsoft (with this driver, I see BT serial port, OBEX and File Transfer in the  BT services).... on the other hand, when I install  Microsoft driver for MSI, I can see only BT serial port in BT services..
Thanks in advance..
Message 11 of 16
(2,911 Views)
Hello. I do not know if you are with a Labview problem or just BT problem. Maybe you wanted to develop BT via labview, just like me.
Anyway, I just know that the key of the BT development on Labview is the OBEX, I can share my source file of Push.vi to you, wish it can be of some help.
I have to notify that as I don't use labview now and do not have a labview installed, I can not be sure if the files are still functional.
Message 12 of 16
(2,889 Views)
Hi, thanks a lot!!!
I just have to ask you, I am missing one  .vi when I open a folder: it is searching for a  ReadBTOBEX.vi and I can't find it.. All other programs are totally functional..
Did you rename maybe some of the existing programs?
I will let you know, if it worked on PDA!
Many thanks!
Smiley Very Happy
Message 13 of 16
(2,873 Views)
Hi, here's another source file for listen,  which was designed for a printer, i did not tested it, in fact I can't open them now as I do not have a labview program. You may have to modify them a lot.
Still, I have to say the key of programming bluetooth on labview is the OBEX, so here I upload a reference of OBEX for you. You can easily develop after reading the attached pdf file. ^_^
Message 14 of 16
(2,844 Views)
Hi
       I am looking similar kind of solution, I tried to unzip the file which you have attached but I am getting a error command stating "No files to extract" could you please provide the proper format.
Regards
VIsuman
Message 15 of 16
(1,101 Views)
May i ask a question about BT function. I hope to use A2DP and HFP function for the BT AUDIO. So may i ask do you take microsoft API to take your transfer file function or just depand on the labview VI.  Do you have similiar experience on it
Daniel
Message 16 of 16
(939 Views)
