ā11-11-2006 06:34 AM
hi, I am trying to make
something similar to you.. I need actually to send file from Pocket PC to
desktop computer, so this means that I have to make a BT PushFile.vi for
a PDA and a BT Pull Fille.vi for a desktop computer.. How did you manage to do
your .vi? Bluetooth is totally knew for me, I was performing only data
acquisition in Labview so far...
I have succeeded so far to perform sending a file via Bluetooth serial port,
but it lasts to long:-( My files are around 1MB..
What kind of a BT Dongle do you have? Maybe that's one of catches.. I have MSI
BT Stick, which originally has Widcomm driver, not supported from Microsoft
(with this driver, I see BT serial port, OBEX and File Transfer in the BT
services).... on the other hand, when I install Microsoft driver for MSI,
I can see only BT serial port in BT services..
Thanks in advance..
ā11-12-2006 06:11 PM
Hello. I do not know if you are with a Labview problem or just BT problem. Maybe you wanted to develop BT via labview, just like me.
Anyway, I just know that the key of the BT development on Labview is the OBEX, I can share my source file of Push.vi to you, wish it can be of some help.
I have to notify that as I don't use labview now and do not have a labview installed, I can not be sure if the files are still functional.
ā11-13-2006 10:10 AM
Hi, thanks a lot!!!
I just have to ask you, I am missing one .vi when I open a folder: it is
searching for a ReadBTOBEX.vi and I can't find it.. All other programs
are totally functional..
Did you rename maybe some of the existing programs?
I will let you know, if it worked on PDA!
Many thanks!
ā11-15-2006 12:48 AM
ā07-13-2011 04:49 AM
Hi
I am looking similar kind of solution, I tried to unzip the file which you have attached but I am getting a error command stating "No files to extract" could you please provide the proper format.
VIsuman
ā11-30-2013 09:55 PM
May i ask a question about BT function. I hope to use A2DP and HFP function for the BT AUDIO. So may i ask do you take microsoft API to take your transfer file function or just depand on the labview VI. Do you have similiar experience on it
Daniel
